Hey guys i have a 06 3.0r wagon. I believe the fogs are H11? Was wondering what upgraded bulbs do you guys put in ? I don't want to dazzle other drivers as i use them constantly at nights. Thanks guys !
Fogs won't be an issue for other drivers if they are aimed correctly. They should basically be shining on the ground out to about 100ft in front of the vehicle. I've been running a set of Auxito 9006 3000K (yellow) bulbs for the last couple years. I like the look and they mainly help to illuminate the sides of the road that the low beams miss. Bulb size in my 05 LL Bean is HB4/9006 which should be the same for the 06s? Expected these bulbs to die shortly after getting water in the housings after a few deep water crossings but they are still working.
Oh awesome thank you for your response. I have the JDM model as im from New Zealand. Maybe they are different? So your just sticking to halogens or are they 3000k leds. Cheers
Ez30r_vvl: I have a 2006 3.0R Wagon. The Fog Light Bulbs are 9006's, Not H11. I have tried Auxito 9006 yellow bulbs. They are very good, But if you want Extraordinary Foglight Bulbs, go with the Morimoto Brand foglight yellow bulbs. They are More expensive, but they're worth it. If you really want to light up the sides of the road in a Big way, go with the Morimoto Brand. Good Luck...
